Page control arrows for PWA
@crazycells Not sure if you are using the scroll-top function, but if you are, I have enhanced the position of the button and re-sized it to match the forward and back arrows as below
The scroll-top button is located on the bottom right.
@phenomlab yes I used it before but not very frequently… Maybe you should put it above… just because it is more intuitive…
v -
@crazycells Ok, but there’s no “scroll-down”
@phenomlab yeah , I know not necessary, but “up” should be above right/left buttons I guess… that is how people would think…
@crazycells Good point, thanks.
@phenomlab but I guess “up” is on mobile, right? not PWA specific?
@crazycells it is, yes - I think I’ll leave it as there is no specific PWA CSS classes I know of. Well, you could use something like the below, but this means multiple CSS files for different operating systems.
/** * Determine the mobile operating system. * This function returns one of 'iOS', 'Android', 'Windows Phone', or 'unknown'. * * @returns {String} */ function getMobileOperatingSystem() { var userAgent = navigator.userAgent || navigator.vendor || window.opera; // Windows Phone must come first because its UA also contains "Android" if (/windows phone/i.test(userAgent)) { return "Windows Phone"; } if (/android/i.test(userAgent)) { return "Android"; } if (/iPad|iPhone|iPod/.test(userAgent) && !window.MSStream) { return "iOS"; } return "unknown"; // return “Android” - one should either handle the unknown or fallback to a specific platform, let’s say Android }
Once you’re in that rabbit hole, it’s impossible to get out of it.
MogoDB v6 to v7 upgrade
Solved Configure -
Custom badges
Solved Customisation -
NodeBB metadata
Solved Configure -
