using exclusive nodebb forum data to create a chatgpt chatbot?
Discussion
  • 9 Votes
    @crazycells yes, I think it certainly has a place - but to enrich knowledge, rather than simply substitute it.
    I remember years ago when I did my exams. You weren’t allowed a calculator or anything like that and had to show your workings on a separate piece of paper which you were given additional marks for.
    These days, they use iPads etc in schools, so the art of writing a letter or needing to perform mathematical calculations in your head is gone. One of my very first jobs was in a newsagent who had a really old till (yes, not a Point-Of-Service like you have today) - all this till did was add up the individual figures, but didn’t tell you how much change to give - you had to do that part.
    Sounds simple enough, but with technology doing everything for us these days, our basic skills (think the “Three R’s”, and see example below) have taken a back seat and I think that’s made us lazy.
    https://www.merriam-webster.com/dictionary/three R's
    Again, my point here being to enrich - not completely replace basic skills we learn as we age.
    @phenomlab Work now 😉
    Seems to be better with some scaling fix for redis on redis.conf. I haven’t seen the message yet since the changes I made
    # I increase it to the value of /proc/sys/net/core/somaxconn tcp-backlog 4096 # I'm uncommenting because it can slow down Redis. Uncommented by default !!!!!!!!!!!!!!!!!!! #save 900 1 #save 300 10 #save 60 10000
    If you have other Redis optimizations. I take all your advice
    https://severalnines.com/blog/performance-tuning-redis/
  • 6 Votes
    @phenomlab said in Q&A Plugin Changes NodeBB:
    float: right;
    left: 10px;
    worked thank you 🙂
    @DownPW That was going to be my next suggestion 🙂
  • Error install plugin
    @pobojmoks
    Not WP plugin but nodeBB but it a known bug
  • Dark Theme Upper Padding
    @DownPW great! thanks a lot… this code solves my problem.
  • NodeBB Footer
    @phenomlab said in NodeBB Footer:
    @jac and you. Hope all is well and you recover quickly
    Thanks pal 😁🤝🏻
